This blog piece intends to introduce a new add-in (i.e. HXPRINCOMP) that implements the procedure developed by Hamilton and Xi (2022).
Table of Contents
- Introduction
- Principal components analysis on cyclical component
- Application to U.S. Treasury Yields
- Application to large macroeconomic data sets
- Files
- References
Introduction
In their paper, Hamilton and Xi (2022) propose a novel methodology when the goal is to extract the common factors behind the cyclical components of each of the series studied. They argue that focusing on the cyclical component of a time series offers a practical advantage; namely, it can be consistently estimated using an OLS regression while remaining agnostic about the stationarity of the underlying series.Principal components analysis on cyclical component
The procedure starts with estimating the following OLS regression for every variable: $$ y_{it} = \alpha_{i0} + \alpha_{i1} \cdot y_{i,t-h} + \alpha_{i2} \cdot y_{i,t-h-1} + \cdots + \alpha_{ip} \cdot y_{i,t-h-p+1} + c_{it} $$ Here, $(h = 8)$ and $(p = 4)$ for quarterly data and $(h = 24)$ and $(p = 12)$ for monthly data. Authors postulate that true cyclical components, $( C_t = (c_{1t}, c_{2t}, \ldots, c_{Nt})^top )$, are characterized by a factor structure $( r \ll N )$ of the form: $$ \underbrace{\mathbf{C}_t}_{(N \times 1)} = \underbrace{\Lambda}_{(N \times r)} \cdot \underbrace{\mathbf{F}_t}_{(r \times 1)} + \underbrace{\mathbf{e}_t}_{(N \times 1)} $$ Authors also show that even if the cyclical components are not observed and are therefore estimated $( \hat{c}_{it} = c_{it} + \upsilon_{it} )$, true factors can still be consistently estimated under certain conditions.Application to U.S. Treasury Yields
As a first example, authors apply their method to treasury yields with different maturities (see Figure 1).
When using principal components analysis on large macroeconomic data sets, one may need to transform each of the variables to ensure stationarity. Since it is done individually, it could be a tedious task. Extracting the cyclical component of series solves this problem by design. As a second example, authors apply their methodology to a large macroeconomic data set (2022-4 vintage of FRED-MD database), which covers 127 variables. To run the procedure on macroeconomic data, once again we can use the add-in (see Figure 4).
Files
References
- Hamilton, J. D., and Xi, J. (2022), Principal Component Analysis for Nonstationary Series, Working Paper, UC San Diego.
Excellent work!
ReplyDeleteThank you very much. I think this method only includes nonstationary series. If we have also stationary and nonstatinary, Hamilton, Xi & Ma (2005) suggested new method which PRINCIPAL COMPONENT ANALYSIS FOR A MIX OF STATIONARY AND NONSTATIONARY VARIABLES. Which code apply this new method on Eviews?
ReplyDeleteIt seems they have changed the title of their work only, not the procedure itself. It still estimates the same regression for each variable, regardless of whether it is stationary or not. So, you can continue to use the add-in as is.
DeleteSorry! New article is Hamilton, Xi & Ma (2025) for mix variables
ReplyDelete
