- Chow-Lin, Denton and Litterman frequency conversion with multiple indicator series.
- Model dependency graphs.
- US Bureau of Labor Statistics (BLS) data connectivity.
- Introduction of the X-13 Force option for forcing annual totals.
- Expansion of the EViews 10 snapshot system to program files.
- A new help command.
1) Chow-Lin, Denton and Litterman Frequency Conversion with Multiple Indicators
EViews’ Chow-Lin, Denton and Litterman frequency conversion methods have been expanded to allow multiple indicator series giving greater flexibility and accuracy when interpolating high frequency data.
The purpose of Chow-Lin interpolation is to use regression to combine higher-frequency series with a single lower-frequency series.  The result is a new high-frequency series that is related to both.  Previously, EViews allowed you to create a new series from a single higher-frequency series and a lower-frequency series; the update now allows you to relate multiple series to a lower-frequency series.  This will be useful for people who want to use multiple inputs (for example, they believe that the combination of several series is better at prediction that a single series) in their interpolation.
See a complete list of Data Handling features added in EViews 10.
2) Model Dependency Graph
We’ve developed a new way to graphically view the
relationship between variables in your model. Colour coding is used to depict
the dynamics in the model, and you can zoom and highlight variables for even
greater clarity.
Whilst EViews has always provided a powerful interface for
creating, editing and solving these models. However, it can be difficult for
the modeller to explain his work to colleagues and clients. The new dependency graph provides a simple
visual guide to how the relationships in the model are structured, allowing
demonstration of the structure of the model.
We plan on improving and adding to the dependency graph feature over the next few releases. If you have any suggestions or requests for the graph (or any other aspect of EViews!) please contact us.
See a complete list of Testing and Diagnostics features added in EViews 10.
3) Bureau of Labor Statistics (BLS) Data
EViews can now connect to the United States Bureau of Labor
Statistics’ API to natively fetch data directly from the BLS into EViews.
The BLS data is also available in other database sources
that EViews supports, such as FRED database. However, adding BLS as a direct data source allows for a quicker data
retrieval.
Although use of the Force option was possible in previous versions of EViews, EViews 10+ provides a new interface to the option, making its use even easier.
Many economic time series have seasonal cycles; consumption or expenditures increase and decrease at certain times of the year. Most official statistics are seasonally adjusted to remove these cycles to allow analysis of the underlying trends in the data excluding the seasonality.
4) X-13 Force Option
EViews’ implementation of the U.S. Census Bureau’s X-13 seasonal adjustment package has been extended to give an interface to the Force specification of X-13, which allows you to seasonally adjust the data, forcing the annual totals to remain at the pre-adjusted levels.
X-13 has become the de-facto standard method of seasonally adjusting monthly and quarterly time series data within the United States and many other countries, and many agencies use the Force option within X-13 as a method of ensuring the adjusted data lines up with the original raw data. The inclusion of this option to the EViews X-13 interface allows easy access to this popular feature.
See a complete list of Computation features added in EViews 10, including other seasonal adjustment routines.
5) Program Snapshots
EViews 10 introduced the popular workfile snapshot system,
allowing both manual and automatic backup, archiving and management of
workfiles. EViews 10+ expands this
system to EViews program files. You can
manually create a snapshot of your EViews program, or let EViews automatically
create backups at specified time intervals. Once snapshots have been made you
can compare the current version of your program with its snapshots, quickly
viewing the differences between the two, and reverting to a previous state if
required.
See a complete list of EViews Interface features added in EViews 10.
6) Help Command
A new help command has been implemented which provides a quick way to access the documentation for a specific command.
i've eviews 10 demo version.i've a problème when i use ARDLeviews stop to fonctioned and a little window say " eviews has stoped to fonctionne,windows seeks to find the solution"
ReplyDeleteemail support@eviews.com with details
Deleteplease send to me
ReplyDeleteUsing BLS data base requires a previous registration. Once it is done I received a key number to initiate the navigation that is showed here. The problem is that the key when entered does not work properly. There is an Error message. Any help? (faiube@gmail.com)
DeleteEviews please, please address this from Dave Giles in Eviews 11, please !
ReplyDeletehttps://davegiles.blogspot.com/2011/11/impulse-response-functions-from-vecms.html
