Since we love Python (who doesn’t?), we’ve had it in the back of our minds for a while now that we should find a way to make it easier for EViews and Python to talk to each other, so Python programmers can use the econometric engine of EViews directly from Python. So we did! We’ve written a Python package called pyeviews that uses COM to transfer data between Python and EViews (For more information on COM and EViews, take a look at our whitepaper on the subject).
Here’s a simple example going from Python to EViews. We’re going to use the popular Chow-Lin interpolation routine in EViews using data created in Python. Chow-Lin interpolation is a regression-based technique to transform low-frequency data (in our example, annual) into higher-frequency data (in our example, quarterly). It has the ability to use a higher-frequency series as a pattern for the interpolated series to follow. The quarterly interpolated series is chosen to match the annual benchmark series in one of four ways: first (the first quarter value of the interpolated series matches the annual series), last (same, but for the fourth quarter value), sum (the sum of the first through fourth quarters matches the annual series), and average (the average of the first through fourth quarters matches the annual series).
We’re going to create two series in Python using the time series functionality of the pandas package, transfer it to EViews, perform Chow-Lin interpolation on our series, and bring it back into Python. The data are taken from Bloem et al in an example originally meant for Denton interpolation.
1. Install the pyeviews
package using your method of choice. We
like the Anaconda distribution,
which includes most of the packages we’ll need. Then, from a Windows command prompt:
conda install -c bexer pyeviews
Alternatively,
if you’re not using Anaconda head over to the pyeviews package
at the Python Package Index and at a
pip install pyeviews
Or, download the package, navigate
to your installation directory, and use:
python setup.py install
2. Start python and create two time series using pandas. We’ll call the annual series "benchmark" and the quarterly series "indicator":
import numpy as np
import pandas as pa
dtsa = pa.date_range('1998', periods = 3, freq = 'A')
benchmark = pa.Series([4000.,4161.4,np.nan], index=dtsa, name = 'benchmark')
dtsq = pa.date_range('1998q1', periods = 12, freq = 'Q')
indicator = pa.Series([98.2, 100.8, 102.2, 100.8, 99., 101.6, 102.7, 101.5,
100.5, 103., 103.5, 101.5], index = dtsq, name = 'indicator')
3. Load the pyeviews
package and create a custom COM application object so we can customize our
settings. Set showwindow (which displays the EViews window) to True. Then call the PutPythonAsWF
function to create pages for the benchmark and indicator series:
import pyeviews as evp
eviewsapp = evp.GetEViewsApp(instance='new',
showwindow=True)
evp.PutPythonAsWF(benchmark, app=eviewsapp)
>>> evp.PutPythonAsWF(indicator,
app=eviewsapp, newwf=False)
Behind the scenes, pyeviews will detect if the
DatetimeIndex of your pandas object
(if you have one) needs to be adjusted to match EViews' dating customs. Since EViews assigns dates to be the
beginning of a given period depending on the frequency, this can lead to
misalignment issues and unexpected results when calculations are
performed. For example, a DatetimeIndex
with an annual 'A' frequency and a date of 2000-12-31 will be assigned an
internal EViews date of 2000-12-01. In
this case, pyeviews will adjust the
date to 2000-01-01 before pushing the data to EViews.
4. Name the pages of the workfile:
evp.Run('pageselect Untitled', app=eviewsapp)
evp.Run('pagerename Untitled annual', app=eviewsapp)
evp.Run('pageselect Untitled1', app=eviewsapp)
evp.Run('pagerename Untitled1 quarterly', app=eviewsapp)
5. Use the EViews “copy” command to copy the
benchmark series in the annual page to the quarterly page, using the indicator
series in the quarterly page as the high-frequency indicator and matching the
sum of the benchmarked series for each year (four quarters) with the matching
annual value of the benchmark series:
evp.Run('copy(rho=.7, c=chowlins, overwrite) annual\\benchmark
quarterly\\benchmarked @indicator indicator', app=eviewsapp)
6. Bring the new series back into Python:
benchmarked = evp.GetWFAsPython(app=eviewsapp, pagename= 'quarterly', namefilter= 'benchmarked ')
print benchmarked
BENCHMARKED
1998-01-01
867.421429
1998-04-01
1017.292857
1998-07-01
1097.992857
1998-10-01
1017.292857
1999-01-01
913.535714
1999-04-01
1063.407143
1999-07-01
1126.814286
1999-10-01
1057.642857
2000-01-01
1000.000000
2000-04-01
1144.107143
2000-07-01
1172.928571
2000-10-01
1057.642857
7. Release the memory allocated to the COM process (this does not happen automatically in
interactive mode). This will close down EViews:
eviewsapp.Hide()
eviewsapp = None
evp.Cleanup()
Note that if you choose not to create a custom COM application object
(the GetEViewsApp function), you
won’t need to use the first two lines in the last step. You only need to call Cleanup(). If you
create a custom object but choose not to show it, you won’t need to use the
first line (the Hide()
function).
8. If you want, plot everything to see how the
interpolated series follows the indicator series:
# load the matplotlib package to plot
import matplotlib.pyplot as plt
# reindex the benchmarked series to the end of the quarter so the dates match
those of the indicator series
benchmarked_reindexed =
pa.Series(benchmarked.values.flatten(), index = benchmarked.index + pa.DateOffset(months = 3, days = -1))
# plot
fig, ax1 = plt.subplots()
plt.xticks(rotation=70)
ax1.plot(benchmarked_reindexed,
'b-', label='benchmarked')
multiply the indicator series by 10 to put it on the same scale as the
benchmarked series
ax1.plot(indicator*10,
'b--', label='indicator*10')
ax1.set_xlabel('dates')
ax1.set_ylabel('indicator
& interpolated values', color='b')
ax1.xaxis.grid(True)
for
tl in ax1.get_yticklabels():
tl.set_color('b')
plt.legend(loc='lower
right')
ax2
= ax1.twinx()
ax2.set_ylim([3975,
4180])
ax2.plot(benchmark,
'ro', label='benchmark')
ax2.set_ylabel('benchmark',
color='r')
for
tl in ax2.get_yticklabels():
tl.set_color('r')
plt.legend(loc='upper
left')
plt.title("Chow-Lin
interpolation: \nannual sum of benchmarked = benchmark", fontsize=14)
For more information on the pyeviews package, including a list of functions, please take a look
at our pyeviews whitepaper
on the subject.
References:
I feel that this is an extremely important development for EViews. The COM interface with Matlab especially has been particularly useful in at least two projects I've worked on, and pyeviews will likely be even moreso. Great work.
ReplyDeleteBy any chance are you guys working on REviews? (R instead of Python)
ReplyDeleteWhat would such a thing do? We already have COM connectivity to R from EViews.
Deletegreat
ReplyDeleteThis comment has been removed by the author.
ReplyDeleteWhen I try to get the series back in Python, the following error shows up:
ReplyDeleteAttributeError: 'NoneType' object has no attribute 'total_seconds'
Any ideas on how to solve that?
Tks
