A common assumption of time series analysis is that the model parameters are time-invariant. However, as the economic environment often changes, it may be reasonable to examine whether the model parameters are also constant over time. One technique to assess the constancy of the model parameters is to compute the parameter estimates over a rolling window with a fixed sample size through the entire sample. If the parameters are truly constant over the entire sample, then the rolling estimates over the rolling windows will not change much. If the parameters change at some point in the sample, then the rolling estimates will show how the estimates have changed over time.
EViews does not have an extensive rolling regression functionality built-in, but it does offer different ways to perform rolling regressions:
- Write an EViews program: we can estimate an equation for each sample in the roll, and then save the results. The following EViews forum posts provided detailed examples.
| You can also find more detailed examples of rolling regression under your Help menu in EViews. Go to: Help/Quick Reference/Sample Programs & Data/ then click the roll link for detailed examples.
- The "Roll" Add-In is a simple EViews program that is integrated into EViews, allowing you to execute the rolling regression program from a single equation object.
- Use the EViews rolling regression User Object: EViews allows us to create a new roll object and store various coefficients or statistics from each iteration of the roll.
Download and Install Roll User Object
To download and install the object class definitions from the EViews website, go to EViews file menu and select Add-ins/Download User Objects, and select the Roll user object from the list box. Click on the Install button to download the Roll user object.
Once we have registered the roll user object, we can think of it as a built-in EViews object. More information about registering user objects can be found at our online help site.Rolling Regression User Object Applied Example
In the following example, we will use the EViews workfile “Demo.wf1” that was saved to your computer when EViews was installed. The file can be found on your hard drive at: \EViews 9\Example Files\EV9 Manual Data\Chapter 02 - A Demonstration.
Since we will use the existing equation EQ01 in our workfile, click OK to accept the default. Then, we will see the next dialog which asks us to select the type of rolling regression:
Rolling Type
Fixed window: the window size specifies the fixed number of observation in each window and the step size specifies how far ahead the window is moved each time:
Click on Proc/Extract rolling coefficient statistics, this will allows users to save various coefficients or statistics from each iteration of the roll.
ReplyDeleteThank you ~!
ReplyDeleteI have used an eviews program to estimate rolling betas for 1200 stocks. however, the estiamtes are stores in a separate file for each stock. How can I view them together so I can copy into excel?
ReplyDeletehttp://forums.eviews.com/viewtopic.php?f=5&p=54124#p54124
DeleteDid you roll it for 1200 stocks at a go Or separately?
Deletesir
ReplyDeleteHow we want to know the size of the windows?
tq
Please how can you provide us with an example of how to estimate a state space VAR with the following variables GDP CPI FDI
ReplyDeleteI am using student version of eviews. Would you please help me to get rolling function as it is not on my menu bar. Important function to perform various model.Is their any way to install add ins (roll function) in eviews as I think student version is not providing the same?
ReplyDeleteThe Student Version of EViews (no longer for sale) does not allow programming or add-ins, so you cannot use the add-in. The University Edition (http://www.eviews.com/EViews10/EViews10Univ/evuniv10.html) does allow add-ins and programming.
DeleteThis comment has been removed by the author.
ReplyDeleteThanks for this easy to understand thread on running rolling regressions on EViews. However, can the same be done if there's a lagged dependent variable (LDV)? It states that the rolling coefficients for LDV is not defined. Is there any way to get around this issue?
ReplyDeleteplease can some one tell me how to apply a rolling regression techniques .It would be big favour to me .Thank you in advance.Waiting for your favourable reply.please respond to my email id..shettysoumya8509@gmail.com
ReplyDeleteHi, I got a message suggest that "_group is not defined" after I rolled a regression and started to forecast, can you please help to fix it?
ReplyDelete
